I just upgraded to Freeway Pro 5.6.2 and everything went pretty well, or so I thought. I just noticed that I’m having problems with CSS Menus. My Main (Home) template works fine, but all of my other templates have a problem with the submenu pull downs. Basically any item after the first is being cut-off.
Easy enough fix I thought. Why not just delete the CSS Menu from all of the other templates and replace them with the Main template menu? Didn’t work. Although the CSS Menu functions fine in the Main template, and any associated pages based on that template, the other templates, and associated pages, revert back to a CSS Submenu that’s cut-off.
Any suggestions?
Just answered my own question.
It appears that the CSS Menu height needs to be tall enough to accommodate all of the submenu items. Why a height of just 35 pixels for a four item submenu is working in the Main template is beyond me.
I guess I’m not as smart as I thought. Although that solved the CSS Menus Submenu issue, now all of the other items on each page are getting pushed around. Any advice?
Wow. I’m a real dumb bunny tonight. It was a layer issue. Time to go to bed. LOL
