I have a lot of pdf’s for download on my next project. I wanted to add an index to each one where the user can click on the page number and go to the correct page in the pdf document. I set up the index in Preview using the link tool. When viewed in preview the links go to the correct page. However in the default window they open in all the links are one page number out. The same happens in windows explorer vrs viewing in Adobe pdf viewer.
I don’t think you can anchor into a PDF from outside the PDF. It’s not HTML inside, and the syntax is entirely different.
On May 10, 2012, at 5:07 PM, Nigel Gilbert wrote:
Hi,
Thanks all. The linking is completely within the pdf. If you open the pdf, look at the index on page 2. If you click on the the page number, that should take you to that page within the pdf. Depending on the viewer, this works or is a page out.
For that much effort, I think that I would OCR the works for searchable and more easily readable content, leaving the PDFs as historical preservation of original forms.
Have you tried doing this using Acrobat itself using the pro version!
If not that might be a consideration and I am sure that one of us might be able to try it for you.
Thanks. Unfortunatly I didn’t see this particular behavour untill i’d finished doing all of the 80+ pdf’s I have. I may try downloading the demo from adobe and see I can just do save from it on all of them.
