They only have to be available to your Mac. So they can be on your
local hard drive, a network shared drive, your Dropbox, pretty much
anywhere that Mac OS can resolve a link to the file. Each time you
publish, all linked files (and this is a VERY broad definition – any
picture, movie, sound, PDF, whatever that you have placed on your
pages within Freeway’s design interface or through an Action) will be
checked against Freeway’s internal record of when that file was last
saved. If the file has changed, a new copy of that file will be
made within the Resources folder, and if you upload, that new copy
will replace the old version on the server. There is never any need to
maintain a particular location for any file that Freeway uses.
Now, all of that is true, but if you work with other designers, or
need to have a handle on your files so that you can find something
later, it’s a very good idea to lay out a project folder similar to
how Freeway builds a project when you use the templates:
my groovy project/
Media/
music.mp3
white_paper.pdf
MyGroovyProject.version1.freeway
MyGroovyProject.version2.freeway
Site Folder/
index.html
Resources/
But if you don’t need this level of organization, trust me, Freeway
can find the files wherever you put them. (Internally, it stores a Mac
OS Alias to each original, and those have an extremely robust lookup
scheme, even to the point of mounting a remote server by dial-up if
you still use that.)
One last point: unless you know precisely what you are doing, and have
an extremely great reason for doing it, NEVER add or remove or modify
anything within the Site Folder or any of its child Resources folders.
Freeway expects that to be its domain, and it will blithely overwrite
any changes you make there, considering any changes that it didn’t
make to be damage worthy of correction.
On Jul 3, 2011, at 4:56 AM, John Bates wrote:
Hi folks. Can someone give me some advice about where I should save
various files that I wish to use with the ‘Link to File’ and ‘Link
to PDF’ actions. Also, what about graphics files? Do they go into
Site folder, Media or Resources?
