I just upgraded to 5.5 and I cannot figure out where to create a showcase gallery. Any suggestions?
Showcase is a standalone app that comes with 5.5 - did you put it in your apps folder when you installed 5.5?
Once you have created the gallery in Showcase you use the showcase action on your FW page and import the gallery you created.
Can the images have a description or a number, preferably the original camera number so a client can order pictures using the gallery???
www.demetriad.com
Dan:
Do you really want that splash page on your site? It really serves no purpose other than to make the user click an extra time.
Just a thought.
Martin
Signal Mountain, TN
www.demetriad.com
There is an option to show a Caption where you can put anything you like.
Thanks David.
I used it before on a client site, just when it came out and there was no provision for text at that time. I remember asking the same question then on the forum.
I am glad that it has been fixed. I will check it out, and/or download a newer version???
As you are using Pro 5.5.2 - you should definitely upgrade to 5.5.4 as there has been some bug fixes and the latest version of Showcase comes with it.
Thanks again.
I did upgrade. I will try it tomorrow.
Dan
