Try this link in your mobile phone and see the footer is halfway up the page. How do I get it to stay at the bottom?
Try the following:
Select #item9 and rename it to footer (or something else more meaningful) in the name/ID field.
Then in the inspector → first tab → Format, Positioning
click the 4th icon (bottom inset) and enter 0px. See if it works.
Thanks. It was already set to 0, but I needed to change V. alignment to bottom and then it worked.
