Thank you for your incredibly well-worded essay on positioning, Ernie. Nicely said! I’ve been using Freeway since before version 1, so I can chime in on the historical aspects here. While I cannot explain some of these choices, I can at least point out what has come before, and from the perspective of a user, but not an in-house developer of the code tree, why they might have made some of these choices.
Freeway began life as a print DTP application named Uniqorn. It was a direct competitor to QuarkXPress during the 2.3.x version era of QXP, IIRC. Because it was “Steved” with the removal of QuickDraw GX from the Mac OS, and because Uniqorn had the ability to create Java “widgets” out of print page layouts (yes, this is what passed for trans-media design in the early- to mid-90s), while the developers of Uniqorn were casting about for something to do for a living, they were already primed for the Web as an output medium.
In any DTP application, there is a page model, and within that, an object model. Each object on the page may contain other objects (including text). This mapped pretty neatly to the dominant “layout” technique for Web in that day — invisible tables with clear GIF spacers.
Freeway 1 let you have the notion of a true WYSIWYG layout space, wherein you could draw things — even overlapping HTML items or graphics — and Freeway would simply create the mother of all tables to translate your layered workspace into a single, flattened table. This would often lead to some nasty issues of images being invisibly sliced and then dragged apart when text to their left or right was scaled by the browser, but even this was easily worked around by making a deeply nested table (drawing an HTML box, sending it to back, then nudging it with the arrow keys to make it one pixel larger right and bottom than the elements it was meant to “contain”).
Freeway 2 let you add independently-positioned “Layers” (named for the Netscape Navigator name for that feature), but these were difficult to integrate with the remainder of the page layout, since that was naturally done in a table in order to deal with the browsers of the day and their independent notions of font size, leading, and other basic typographic niceties. Fonts were still measured in +1, -1 keyword increments, as I recall. About the only thing I ever used layers for was to have a message slide into the page, using the then-revolutionary Move Layer Action to slide the div into the page from off-screen somewhere. Otherwise, they were still too new for the browsers of the day. Freeway 2 also introduced the idea of the inline table, and I recall many times making a single-cell table in order to create a nested inline element (since you couldn’t insert an HTML item in another HTML item until version 3) and using that to provide a captioned inset image within a run of text. That, and adding padding to the side of a photo in Photoshop so it wouldn’t crash into the text too awfully when floated left or right in a paragraph.
Freeway 3 introduced the Layers-First style of the Freeway we know today, as browsers had by then caught up to the brave new world of CSS for everything. This began to be a problem for long-term users, because the natural constraints imposed by a table-based layout were removed, but so too were the natural advantages of that layout technique (awful and non-semantic as it may have been). Table layouts are still to this day entirely unbreakable, which is why they remain in use in the harshest browser environment on Earth — e-mail. I cannot even begin to imagine how many answers I have posted to FWTalk have dealt with layers sliding over other layers when their site is viewed in a cranked-font browser (or Windows XP).
This transition was in many ways one of the most difficult of Freeway’s history, because while the developers knew (and know) that inline is the way things should be done, they could not untwist the basic assumptions of DTP in a meaningful way, and still maintain usability for their established customers or their market base of traditionally-trained designers. It comes down to the basic problem of figuring out what the user MEANS when they overlap two things or place them near one another. Do they want them to be independent layers, or do they want them to be merged into a third object, or do they want one to push the other away? Inventing a whole new interface modality that allows a designer to signal the fine points of intent without obscuring the design elements in the process — that’s genuinely hard to imagine.
Brave pioneers such as Dan Jasker popularized the idea of nested inline layouts, which return that degree of flexibility and resilience to a DIV-based CSS layout, albeit at the expense of everyday workflow convenience. The pain of having to design your pages twice — once for what you want it to look like, and once for how you want the browser to interpret the HTML — has driven more than a few designers away from Freeway once they attain enough knowledge about the medium to want to work “smarter”.
Remember, “as the twig is bent”: Freeway of today is still a child of Uniqorn and DTP. Its page model is entirely print-centric and not aligned with the browser’s DOM. When you drag things around in the design view, you are modifying the traditional DTP object model, with its x,y,z coordinates and dimensions and all. Each item lives on its own sheet of glass in the animation camera stand, and cannot touch any of its neighbors. When the final page is composed to HTML in the “print” (publish) process, that object model is translated to HTML (dumbed down, I like to say). But because this process happens last, and only in an output stage where the final result is entirely divorced from what you see on screen as you design, there is no meaningful way for Freeway to let the DOM into its design view and give you better feedback about how the final HTML will be constructed.
Finally, it’s been a long-term problem for designers to not care about the messy bits behind the glass until it gets to be a problem. Then they raise their fists and blame Freeway for not reading their mind. It’s a genuinely hard problem that Freeway has carved out for itself, and the alternative is a cliff-shaped learning curve. I have been fortunate to have long legs and a force of will you cannot believe, and I have been paying out the rope behind me for the other climbers since 1998 or so (1997-8 were basically coming to terms with Freeway and browsers and asking so many questions that the developers on the mailing list were plenty sick of me). I continue to bang the drum that you should learn as much about HTML, DOM, CSS, and JavaScript as you can possibly learn — it’s the paper grain and dot gain and ink coverage of your chosen medium. Ignore them at your peril.
On Oct 25, 2014, at 12:15 PM, Ernie Simpson email@hidden wrote:
That last bit is harder to answer because I don’t understand just where the
developer’s strategy is leading us. Old-timers may correct me, but I think
at one time Freeway made every drawn item relative by default. Using the
inspector, you could change the position to a value of absolute or fixed.
As of version 6 at least (I still have 7 in a box until I finish my current
project, soon I hope) all drawn items are positioned as absolute, with
fixed the only other choice.
