[Pro] Window size
Okay, this is stupid. I’ve moved my work from a large monitor to a smaller monitor and now the bottom of the Freeway window can’t be seen. I know that I can re-size the window on my other Mac, and then bring the page back to the MacBook. But is there a way of re-sizing the window without that hassle? In other words, I can’t see any of the info at the bottom of the Freeway window–links, etc.
Thanks very much.
Britt
In the top left corner of all Mac OSX windows are three buttons. The blue one is the button you should focus on.
Sorry…meant green button. These old eyes of mine…
It’s green to my old eyes but it worked. Thanks very much.
Bear in mind that if you have System Preferences>Appearance set to
‘Graphite’ then they are all the same colour. It’s the rightmost button.
Similar problem to when people used to call the CSS button in Freeway
the ‘blue button’; it depends.
best wishes,
Paul Bradforth
http://www.paulbradforth.com
