• Yes, I heartly agree, timers for slide show modes in all the modules, especially Impress.
• Allow timed shows to simply stop on last photo, automatically close, or loop.
• Oh, not sure this can be done, but if at all possible - be able to use navigation arrow keys on keyboard to advance or go-back in a slide show mode.
• Make each window in Impress a clickable link to take one to get further info on ‘featured’ item. This way one can have focused banners that really do more.
• PNG’s! Support for PNG graphics would be way cool!
• Can one/Where can one enter the header/title information for an overall slide show, not just each individual photo?
If it takes another vote to help the project proceed, put me in for all mentioned. Clicking the banner and a little more control of images would be helpful.
It would be great if instead of having to click on a single image to open the Bloxx gallery, it would be great if the Bloxx gallery could be set to open automatically when the viewer goes to the page.
With this acton, and it’s a very welcomed action, if one clicks on a Blox stack before the auto opening time, Blox doesn’t behave as it should. ie. There seems to be some problems, unless one waits for the auto-opening to happen. - Lewis
Controls, controls controls. Exhibeo is FAR too “off the peg” ready for me. I dont want a gallery or slideshow that is almost exactly the same as everybody else’s - I need to customise almost every paramater - basically if its a variable I want to be abe to adjust it - if I can’t a “tool” soon becomes a toy - nothing more. I played with exhibeo for 10 minutes tops and half of that was hunting around thinking that there had to be more controls than this- I was wrong, it’s in my trash can.
Ma è così difficile e laborioso permettere ad exhibeo di gestire i link?
Sembra la Apple con l’iPhone… questo non si puó, questo non si fà, questo non è possibile, quest’altro non è permesso… Ma si, ma no, ma su, ma dai, muoviamoci!
