How can i get my work page to look this this? With hover over the thumbnail and visitors can zoom in or click link
http://aeoninternetmarketing.com/portfolio/
In its simplest form you could use Target Show/Hide to get the Magnify and Link graphics to appear over the thumb. The slide down and opacity change would require a bit more work and some CSS or Javascript.
You can then use ScriptyLightbox on the Magnify icon to get the bigger image to appear while a standard link on the Link icon will take you to the new page.
This example has gone a step further than that but it is doable in FW.
I just want the magnify and link option. I think it would add a cool element to my page
Quick example that uses CSS3 Rollover action on the Thumb to change the opacity, Rollover action on the thumb to Trigger Target Show/Hide on the Magnify and Link icons.
ScriptyLightbox2 on the Magnify icon linked to the larger image and conventional link on the Link icon to the actual page(s)
http://www.deltadesign.co/FW6Test/magnify.html
Your example is exactly what I want! Thanks for showing how it works
This is what I want
