”);$(“#” + el.id).append(“
”);$.setFields(el);if (params[el.id].navigation) {$.setNavigation(el);}$.transition(el, 0);$.transitionCall(el);};$.setFields = function (el) {tWidth = sWidth = parseInt(params[el.id].width / params[el.id].spw);tHeight = sHeight = parseInt(params[el.id].height / params[el.id].sph);counter = sLeft = sTop = 0;tgapx = gapx = params[el.id].width - params[el.id].spw * sWidth;tgapy = gapy = params[el.id].height - params[el.id].sph * sHeight;for (i = 1; i <= params[el.id].sph; i++) {gapx = tgapx;if (gapy > 0) {gapy–;sHeight = tHeight + 1;} else {sHeight = tHeight;}for (j = 1; j <= params[el.id].spw; j++) {if (gapx > 0) {gapx–;sWidth = tWidth + 1;} else {sWidth = tWidth;}order[el.id][counter] = i + “” + j;counter++;if (params[el.id].links) {$(“#” + el.id).append(“
”);} else {$(“#” + el.id).append(“
#cs-” + el.id + i + j).css({‘background-position’:- sLeft + “px " + (- sTop + “px”), left:sLeft, top:sTop});sLeft += sWidth;}sTop += sHeight;sLeft = 0;}$(”.cs-" + el.id).mouseover(function () {$(“
#cs-navigation-” + el.id).show();});$(“.cs-” + el.id).mouseout(function () {$(“
#cs-navigation-” + el.id).hide();});$(“
#cs-title-” + el.id).mouseover(function () {$(“
#cs-title-” + el.id).mouseout(function () {$(“
#cs-navigation-” + el.id).hide();});if (params[el.id].hoverPause) {$(“.cs-” + el.id).mouseover(function () {params[el.id].pause = true;});$(“.cs-” + el.id).mouseout(function () {params[el.id].pause = false;});$(“
#cs-title-” + el.id).mouseover(function () {params[el.id].pause = true;});$(“
#cs-title-” + el.id).mouseout(function () {params[el.id].pause = false;});}};$.transitionCall = function (el) {if (params[el.id].delay < 0) {return;}clearInterval(interval[el.id]);delay = params[el.id].delay + params[el.id].spw * params[el.id].sph * params[el.id].sDelay;interval[el.id] = setInterval(function () {$.transition(el);}, delay);};$.transition = function (el, direction) {if (params[el.id].pause == true) {return;}$.effect(el);squarePos[el.id] = 0;appInterval[el.id] = setInterval(function () {$.appereance(el, order[el.id][squarePos[el.id]]);}, params[el.id].sDelay);$(el).css({‘background-image’:“url(” + images[el.id][imagePos[el.id]] + “)”});if (typeof direction == “undefined”) {imagePos[el.id]++;} else if (direction == “prev”) {imagePos[el.id]–;} else {imagePos[el.id] = direction;}if (imagePos[el.id] == images[el.id].length) {imagePos[el.id] = 0;}if (imagePos[el.id] == -1) {imagePos[el.id] = images[el.id].length - 1;}$(“.cs-button-” + el.id).removeClass(“cs-active”);$(“
#cs-button-” + el.id + “-” + (imagePos[el.id] + 1)).addClass(“cs-active”);if (titles[el.id][imagePos[el.id]]) {$(“
#cs-title-” + el.id).css({opacity:0}).animate({opacity:params[el.id].opacity}, params[el.id].titleSpeed);$(“
#cs-title-” + el.id).html(titles[el.id][imagePos[el.id]]);} else {$(“
#cs-title-” + el.id).css(“opacity”, 0);}};$.appereance = function (el, sid) {$(“.cs-” + el.id).attr(“href”, links[el.id][imagePos[el.id]]).attr(“target”, linksTarget[el.id][imagePos[el.id]]);if (squarePos[el.id] == params[el.id].spw * params[el.id].sph) {clearInterval(appInterval[el.id]);return;}$(“
#cs-” + el.id + sid).css({opacity:0, ‘background-image’:“url(” + images[el.id][imagePos[el.id]] + “)”});$(“
#cs-” + el.id + sid).animate({opacity:1}, 300);squarePos[el.id]++;};$.setNavigation = function (el) {$(el).append(“
#cs-navigation-” + el.id).hide();$(“
#cs-navigation-” + el.id).append(“
prev”);$(“
next”);$(“
#cs-prev-” + el.id).css({position:“absolute”, top:params[el.id].height / 2 - 15, left:0, ‘z-index’:1001, ‘line-height’:“30px”, opacity:params[el.id].opacity}).click(function (e) {e.preventDefault();$.transition(el, “prev”);$.transitionCall(el);}).mouseover(function () {$(“
#cs-next-” + el.id).css({position:“absolute”, top:params[el.id].height / 2 - 15, right:0, ‘z-index’:1001, ‘line-height’:“30px”, opacity:params[el.id].opacity}).click(function (e) {e.preventDefault();$.transition(el);$.transitionCall(el);}).mouseover(function () {$(“
”).appendTo($(“
#coin-slider-” + el.id));for (k = 1; k < images[el.id].length + 1; k++) {$(“
#cs-buttons-” + el.id).append(“
” + k + “”);}$.each($(“.cs-button-” + el.id), function (i, item) {$(item).click(function (e) {$(“.cs-button-” + el.id).removeClass(“cs-active”);$(this).addClass(“cs-active”);e.preventDefault();$.transition(el, i);$.transitionCall(el);});});$(“
#cs-navigation-” + el.id + " a").mouseout(function () {$(“
#cs-navigation-” + el.id).hide();params[el.id].pause = false;});$(“
#cs-buttons-” + el.id).css({left:“50%”, ‘margin-left’:- images[el.id].length * 15 / 2 - 5, position:“relative”});};$.effect = function (el) {effA = [“random”, “swirl”, “rain”, “straight”];if (params[el.id].effect == “”) {eff = effA[Math.floor(Math.random() * effA.length)];} else {eff = params[el.id].effect;}order[el.id] = new Array;if (eff == “random”) {counter = 0;for (i = 1; i <= params[el.id].sph; i++) {for (j = 1; j <= params[el.id].spw; j++) {order[el.id][counter] = i + “” + j;counter++;}}$.random(order[el.id]);}if (eff == “rain”) {$.rain(el);}if (eff == “swirl”) {$.swirl(el);}if (eff == “straight”) {$.straight(el);}reverse[el.id] *= -1;if (reverse[el.id] > 0) {order[el.id].reverse();}};$.random = function (arr) {var i = arr.length;if (i == 0) {return false;}while (–i) {var j = Math.floor(Math.random() * (i + 1));var tempi = arr[i];var tempj = arr[j];arr[i] = tempj;arr[j] = tempi;}};$.swirl = function (el) {var n = params[el.id].sph;var m = params[el.id].spw;var x = 1;var y = 1;var going = 0;var num = 0;var c = 0;var dowhile = true;while (dowhile) {num = going == 0 || going == 2 ? m : n;for (i = 1; i <= num; i++) {order[el.id][c] = x + “” + y;c++;if (i != num) {switch (going) {case 0:y++;break;case 1:x++;break;case 2:y–;break;case 3:x–;break;default:;}}}going = (going + 1) % 4;switch (going) {case 0:m–;y++;break;case 1:n–;x++;break;case 2:m–;y–;break;case 3:n–;x–;break;default:;}check = $.max(n, m) - $.min(n, m);if (m <= check && n <= check) {dowhile = false;}}};$.rain = function (el) {var n = params[el.id].sph;var m = params[el.id].spw;var c = 0;var to = to2 = from = 1;var dowhile = true;while (dowhile) {for (i = from; i <= to; i++) {order[el.id][c] = i + “” + parseInt(to2 - i + 1);c++;}to2++;if (to < n && to2 < m && n < m) {to++;}if (to < n && n >= m) {to++;}if (to2 > m) {from++;}if (from > to) {dowhile = false;}}};$.straight = function (el) {counter = 0;for (i = 1; i <= params[el.id].sph; i++) {for (j = 1; j <= params[el.id].spw; j++) {order[el.id][counter] = i + “” + j;counter++;}}};$.min = function (n, m) {if (n > m) {return m;} else {return n;}};$.max = function (n, m) {if (n < m) {return m;} else {return n;}};this.each(function () {init(this);});};$.fn.coinslider.defaults = {width:565, height:290, spw:7, sph:5, delay:3000, sDelay:30, opacity:0.7, titleSpeed:500, effect:“”, navigation:true, links:true, hoverPause:true};})(jQuery);//
