How do you wrap text around an image (graphic) in FwyPro7?
You can insert an image in a run of text and set the padding/margin on the image to keep the text away but the text will not follow the contours of an image that is not rectangular.
If you are looking for text to follow around the sides of an image then you will need a solution something like Paul’s Text Flow action
http://www.actionsworld.com/Actions/TextFlow/index.php
http://www.actionsworld.com/Actions/TextFlow/moreinformation.php
Thanks. I tried that but the text doesn’t go alongside, it leaves a big gap. I just emailed Paul to see if his action works for Fwy7 (his website lists Fwy5)
lists Fwy5)
You may need to “float” the image… insert the image at the beginning of a
paragraph, then with the image selected, check out the Inspector position
controls for float left or float right.
Thank you! I think It’s going to work.
