hi max,
i’ve a huge problem with the wy menu styler. when i placed a web yep menu without styles inline in a content box, the menu stays where i placed it. but if i attached the styles with the menu styler, the menu fills out the content box (it should be under the blue box “UNSERE ANWÄLTE”
check! as it seems, the wy css styler don’t work on inline objects. i put the menu out of the content box and made it a “normal” (not an inline) object/menu and now it works …
… but now another problem occurs: when i entered 8 menu items (persons) the first entry is not visible. instead of this menu item there is an empty small box above the other seven.
it’s a very simple menu without a submenu …
hi ray you can use the webyep menu as an inline but you need to name the container the webyep item is in with the name MyMenu.
Is there any chance I can have a look at your freeway artwork so I can see how you have constructed your artwork
