Hey Walt,
Looks like I have migrated to 6.1 from 5.5 and have some very minor issues to work thru.
You came to mind for the first since we set this up a while ago and something bizarro is happening.
What we set up on 3 pages was a search box… Visitor types in what they are looking for and using protaculous (at the time) the results appear below as the person types.
Now on these 3 pages in 6.1…
I noticed the text field box that we used was gone and then I noticed that for some reason it planted itself behind my main logo (top left). You can see it there (white).
In the FW document I cannot get to it and in the place where it was is just an html box.
I am having another issue on this page with BG Table ROllover action but not sure if they are related to 6.1, protaculous 2, each other, or separate.
Figured I would start with just fixing this search box that we made.
http://www.hoffkids.com/assortedfun.html
http://www.hoffkids.com/mathlinks.html
http://www.hoffkids.com/sciencelinks.html
thanks
Barry
Dave and Walt,
here is a TEST page with the problem
It is a suplicate of one of the 3 pages with this weird issue. I deleted soem icons and such to strip it down.
Protaculous 2 is on the page.
I will keep trying now to see how to fix positioning.
http://www.hoffkids.com/assortedfuntest.html
Barry
I have replied in the other thread but I will repeat the question here.
How was the search filter field added to the page as it looks like it is not in the FW layout but added via Markup.
I see
<input id="filter" class="f-x2" type="search" name="filter" size="23" style="width:300px">
But no enclosing Div - but then again I am trying to diagnose this from my iPad.
I would try clicking inside the top table cell of your link list and Insert>Markup Item and add the above code in there.
yes- I think that’s it!!!
yes- works…check it out… I just have to fix the 3 pages now (and then I am down to just 2 fixes after migration- 1 is simple, 1 is not so simple)
click here …
thanks!
Barry
