[Pro] z-index "-1" does not work
if I enter for z-index the value “-1” it will change to “1” in the output. How can I achieve to get the “-1” in the output without changing the file manually after the files been output by FreewayPro?
BR
Alain
Are you trying to replace the PageDiv? The “bild” div in your example is
already the first child of the PageDiv and as such can’t move any further
back.
You can redefine the PageDiv using Walter’s PageDiv Extended action… though
be cautious when using it.
http://actionsforge.com/actions/view/143-pagediv-extended
BR
Alain
Dropbox - Error - Simplify your life
Hi Ernie,
there is a java script which simulate a snowfall. The problem is as long I do not put the “bild” to z-index=-1 the snowflakes are behind the picture.
Nevertheless I would expect that the value I enter in Freeway will be also output accordingly which is not the case here. So this looks like a bug to me.
BR
Alain
It’s a problem for you, but hardly a bug as child items can not be layered
behind their parents.
Can you share a link to the javascript in question so I can see how best to
solve your problem?
On Mon, Dec 3, 2012 at 10:55 AM, Alain email@hidden wrote:
Hi Ernie,
me.
BR
Alain
I have a couple of snow javascripts used with FW - one uses images, the other does not.
http://www.deltadesign.co/fw_examples/other/snowstorm.html
http://www.deltadesign.co/fw_examples/other/moresnow.html
here the file
https://www.dropbox.com/s/4olplw4r418kevf/snowing.txt
BR
Alain
solve your problem?
Alain - do you want the snow in front or behind your picture?
http://www.deltadesign.co/fw_examples/other/yetmoresnow.html
Dave,
thanks for your example - snow should be in front of the picture like on the large penguin.
In my first tests I did it the same way as you with the <div id=“item1” … but this works for small windows only. If you have a larger screen the snowfall is limited in x direction according to the stage size - see also here: Dropbox - Error - Simplify your life
this is why I have putted the code after the tag - see the result here: Dropbox - Error - Simplify your life
but in this case I need to put the “bild” to z-index=-1
BR
Alain
Hi Alain,
Change the script so that the line that paints the snowflakes on the page gives them a high z-index.
Change;
document.write('<span id="s'+i+'" style="position:absolute;top:-'+snowmaxsize+'px">'+snowletter+'</span>');
to;
document.write('<span id="s'+i+'" style="z-index:999;position:absolute;top:-'+snowmaxsize+'px">'+snowletter+'</span>');
The high z-index should mean that the snowflakes appear over the top of your Freeway content.
The Flurry Action (http://www.freewayactions.com/product.php?id=028) will give you a similar effect but with user defined layers rather than text elements.
Hi Tim,
thank you for your hint - this is the easiest way to fix the problem.
I first have used your Flurry Action and everything looked nice in Safari, Chrome and IE9 but in IE6-8 and Firefox the screen start to shake after some time
see here: http://www.michelle-ryser.com/index_snow.html
BR
Alain
Hi Alain,
That should be an easy fix.
Add the following CSS style to your page with the Flurry Action applied to it in Page > HTML Markup > Before ;
<style type="text/css">
body { overflow:hidden; }
</style>
I’ll add this to the Action once I find the original. I think this is an Action that I may have lost the unencoded original for when my raid array died long before I had Time Machine.
Hi Tim,
perfect - thank you for your help.
Yep the Time Machine is a very nice feature and I had more than ones before the Time Machine have been introduced the cases where this would have prevented the loss of some my datas.
BR
Alain
Hi Alain,
I’ve updated the original Flurry Action to include this overflow fix mentioned earlier;
Experienced Freeway designer for hire - http://www.freewayactions.com
Hi Tim,
you are great - thank you very much fro your fast help and also modify your action. Everything works perfect.
BR
Alain
Tim - not sure that your fix is a reasonable solution as it makes it impossible to scroll longer pages.
You cannot scroll down the page to download the action!
Yes, I guess that may be an issue. :slight_smile:
I’ll take a look at that.
