I’ve been using Intaglio program for a few years, and I’ve been very satisfied. Thank you for a good program.
Now, however, I had a problem with a program that I can’t solve.
I imported a PDF file that I spread out for editing. The program was left in a rainbow ball mode and could only be shut down with a forced stop command.
I started the program several times, as well as the computer, but it didn’t help.
I uninstalled the program a few times and reinstalled it, but it didn’t help.
It would seem that the PDF file I was trying to decompress in the program for editing somehow has been left in memory?
Would you have any help with this.
Intaglio mailing list
Could be anything. Is it probably containing multiple pages document? It should open by skipping a warning at least the title page.
Does it open fine in Preview.app and do you have any other PDF-compatible software onboard? Maybe send it over and I´ll try to look into it.
So the problem came at the point when I was trying to make a PDF file editable in a program after it had already been imported. The pdf file works well and it opened well in the program. The file is a one-page house floor plan, but with lots of lines, and layers
So does it work now? A one-pager with “lots of lines and layers” shouldn´t be a problem at all.
As I said you can send it over if you like or allowed to do so. Without at least an problematic example file it´s not possible to help. You can find email address in the notification mail you receive through this forum or make a download link available. For language+translation there´s at least https://translate.google.fi available.
