If you send an email to support(a)softpress.com using the “from” address that you registered/purchased with, the reply will automatically include your serial number(s) at the bottom.
On Aug 5, 2016, at 7:55 PM, David C. White via offtopic email@hidden wrote:
Hi, can anyone help with my activation problem? I purchased Freeway Pro 7 (701) awhile ago, but hadn’t put it onto my comp yet, although I made backup discs…
Upon trying to activate with the serial key, I keep getting a message that the serial is wrong…anyone have any thoughts?
thanks~
