Peter2
(Peter)
1
Hi I’m using bam menus
but when I have some graphics on the page the bam menus appear underneath the graphics.
Not sure what I’m doing wrong.
link below to tests I’m running
webroc.org
click on client area
login: freeway
password: softpress
thanks in advance
Peter
Make sure your Menu and BAM items are all layers and then select them in turn and ‘Bring to Front’
Peter2
(Peter)
3
Hi David,
thanks, done that and works fine. Do you know how I can get the bams to rollover at the same place or at different places below the menu line.
I’ve uploaded a new example.
thanks
Peter
There is an action called CSS Sub Menu position that allows you to fine tune your BAM position.
Get it at http://www.freewayactions.com/test/css-sub-menu-position/
