I made my website in Freeway Pro on my old computer. Now I placed the project and my images on my new computer. My site has a lot of images, which are all placed in one main folder, which contains many subfolders.
Unfortunetly Freeway says that all the images are missing, it can’t find the images on my new computer.
Is there a way that Freeway can find the used files by selecting the main folder? Or do I have to select every image individual, which will be a lot of work.
If you goto “Edit > Resources” you’ll get a list of what’s ‘Missing’ and what’s ‘OK.’ You might have to go through and update each image individually or if there’s duplicates it should update all of the specific file’s.
You’ll just have to tinker with it and see how Freeway handles it.
I guess I just have to update every subfolder individually. At least when I select one image in a subfolder, it recognizes the other images in that same folder as well. It will take a while, but it’s probably the only way.
