Pseudo: nth-letter
I use pseudos all the time without issue but for some reason I’m unable to get the nth-letter to work with the transform property.
If you use Coda you can view/edit the file in real-time using the link below.
see://50.151.97.84:6942/pseudo.html?sessionID=F4C71F9F-446C-4911-84A3-38D960FA25B4
dynamo mailing list
Is nth-letter even implemented? I’ve used first-letter, first-line and some
others, but not that one.
Also, I never figured out the Coda link either. Maybe my Coda’s broken.
below.
see://
http://xiiro.com
dynamo mailing list
dynamo mailing list
http://codepen.io/FWeinb/pen/djuIx
dynamo mailing list
Yeah, but that’s using javascript to create those classes - not real CSS.
http://xiiro.com
dynamo mailing list
dynamo mailing list
Ha! That explains it. Nevermind.
Thanks.
dynamo mailing list
Here’s one way to do it:
Open a file in Coda.
Enable the ‘Share’ link at the bottom of the window.
Enable the ‘Bonjour’ button.
Go to Menu > File > Copy Sharing URL
Send the link to someone.
Collaborate!
dynamo mailing list
Ohh kayy…
Then, what does the person who is sent the link do? I couldn’t get Coda to
do anything with the link you sent before.
Also, menu File > Copy Sharing URL is greyed out for me.
Collaborate!
http://xiiro.com
dynamo mailing list
dynamo mailing list
What should happen (at least in my experience) is that clicking the link (with Coda open) will open the shared file on your computer.
Your Coda file should be open and in edit (not preview) mode, and assuming Share and Bonjour are both enabled for that particular file the Copy URL should now be accessible.
Ohh kayy…
dynamo mailing list
Alternatively, you can copy the url and paste it into the Remote Address field in the Sharing panel of the sidebar.
dynamo mailing list
