Question about Tim's audio.js
I’m encountering a lot of unnecessary uploads of .mp3 files.
I see from Tim’s audio.js I can specify a URL, which means I upload
manually and FW will not try to re-upload?
Can I simply put the filename in the URL box [2014-10_Talk.mp3] if the
.mp3 file is in the same folder as the .html page?
Best wishes Peter
Peter Tucker • Oxford, UK • email@hidden
Yes, that will work exactly as you expect. And Freeway will leave it alone through redesigns of your page. If you make a new compressed version of the file some time later, you can upload it over the original and again, Freeway won’t have to be involved on that end either.
I see from Tim’s audio.js I can specify a URL, which means I upload manually and FW will not try to re-upload?
Can I simply put the filename in the URL box [2014-10_Talk.mp3] if the .mp3 file is in the same folder as the .html page?
Best wishes Peter
