on the example site you gave, the read more expands the div to show “initial hidden text” (so the more).
The read more in WebYep terms creates a new empty page instance so it could be seen as an excerpt read more (jump to an empty new page) which is more the practice in a blog-surrounding.
Julie
hi Julie
what you will need to do is create webyep loop and in that loop you need to create an accordion triggered panel which in turn contains a webyep text area
That way when you create anew loop it and reveal the read more area you can add new text
I hope that makes sense
HI,
do I put it all on the same page…
It does in a way…
Thanks Max
On Oct 18, 2013, at 11:50 AM, max email@hidden wrote:
hi Julie
Hi Julie sorry about the terrible grammer in my reply… as you can tell, I was rushing. If you can tell me which version of freeway your running and which javascript framework you would prefer then I can quickly mock something up for you.
