purity
(purity)
January 30, 2016, 12:39am
1
Hello,
does somebody know where to find a STEP BY STEP tutorial how to make web yep (1.0) images responsive?
greets
ray
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins π
Likes: 1 β€
Hi Ray
it depends on how you have inserted the webyep image into your document but lets say its like this simple example
create a new page
click inside the page until you see a flashing cursor and insert a webyep image via :
insert/action item/webyep image
in the inspector palette change the width to percentage so for this example lets say 33% and the height to flexible.
in the action palette add a name in the name field
and the change the scale method to βDo not scale widthβ and "Do not scale height
click on the IMG Tag Extended button and copy and paste this into the popup window:
style=βwidth:100%; height:auto;β
and now publish
thats it⦠the webyep image will be inserted and be flexible
if you want the image to be bigger then change the (step 2) 33% to say 50%β¦ etc
kind regards max
Likes: 1 β€
purity
(purity)
January 31, 2016, 6:00am
3
Hi Max,
cool, thanks a lot for your help!
greetz
ray
Likes: 1 β€
purity
(purity)
January 31, 2016, 5:38pm
4
Hello Max,
i did what you wrote, but something went wrong and the pictures donβt change their width. Is this because I use this method in another html box (the WY images are in a loop) with a 100% fixed width?
http://www.grayfix.at/planc_test/englisch/news.php
kind regards
ray
Likes: 1 β€
hi ray unfortunately I can see errors in your code
unfortunately the quotes above have been interpreted incorrectly by the editor so I will write that again so you can copy and paste
style="width:100%; height:auto;"
can you alos make sure you have set the webyep image to do not scale on both height and width plus have you used percentatges in the inspector?
speak soon max
Likes: 1 β€
purity
(purity)
January 31, 2016, 6:55pm
6
Hi Max,
thank you again, now it works!
It must have been the quotes β¦
Yes, the images do not scale and i gave them a width of 22% and a right-margin of 4% (4 pics and 3 margins) β and yes, the height is flexible.
kind regards
ray
Likes: 1 β€
great
i should have noticed last night that the quotes were wrong
kind regards max
Likes: 1 β€
