Does anyone know if these Actions will only work on Freeway Pro? Thanks, Dave
actionsdev mailing list
I think that they are Pro only.
I assume that you have express?
Remember that each of these actions has 20# options and also 10 Target groups - that makes 200 unique selectors.
Is that not enough?
I don’t know what ‘10 Target Groups’ means. I’m trying to do a rollover gallery that features 24 thumbs, thus need 24 target images. But it is limited to 20?? Dave
You can choose any 1 of 20 target numbers for each Target group so that means that you have 200 options - far in excess of the 24 you require.
When you set up the action you choose your Target # (1-20) and your Target group (indigo, aqua, cadmium etc etc)
So for thumbs 1-20 you can use Indigo group and nos 1 -20 for the next 4 (20-24) you can use aqua and 1-4
So you can have 200 thumbs
Try it and see.
Is this something you can do in Freeway Express? None of this makes any sense to me, Indigo, aqua, cadminum?? I’ve done about 15 rollover gallerys so far on this website. The biggest had 18 thumbs. After I stack the target images, I go to item/actions/target image. There is no place I see groups. In the action window it won’t let me do more than 20 target images.
This may be an Express limitation but if you look at the Rollover action palette with the Parameters tab selected go down near the bottom.
Is there a Target Group drop down selector?
Does it have 10 options?
Example http://www.deltadesign.co/examples/gallery.html
Top row Indigo, bottom row aqua (haven’t done them all just enough to show more than 20 with the standard actions.
