Does anyone know if there Is there a trick of some sort to get rid of the jagged edges that occur when you rotate a graphic? It seems to be irrelevant whether it’s a jpg, png, pdf or eps, and importing high-resolution images/graphics still give the jagged look.
How do I put twitter updates on to a web page. I’m using Freeway 5 pro.
I can access the html code on the twitters site, but I have no idea about transferring it over to the site I’m building.
Any help will be appreciated
Try Page / Insert / Markup Item. Paste the code they gave you into the
dialog that appears, and Okay the dialog. Look carefully on your page
for a new 100px-square box with a little [H] in the upper-left corner.
Move and resize this box to where you want the updates to appear. Note
that this will be unstyled, unless you create a text style and apply
it to the box. Note that all you will ever see in your design view is
the bare empty box with the little [H] in it. To view the actual
rendered code, you’ll need to preview in a browser. To change this
code in the future, click once on the box to select it, then choose
Item / Modify from the main menu.
pro.
