The ST action on my page doesnt work when the RPL is applied. Once the RPL is removed, the ST behaves normally.
I can get the page working with the new gallery action, but would rather stick with my ST than redo all the pages again. Is this happening for others? and if so, is there a work-around?
Place all the targets inside a container HTML item and apply the Remove from RPL Action to them. that should do it.
I have a set of graphic rollovers on the master page - they appear ok on all the pages apart from 2 where they have moved down the page. I have the same format on all pages which makes it odd why they only move on 2 pages.
I have tried putting them in their own container, but then I get javascript errors.
