Can anyone help me out on this one? I have a thumbnail with a Scripty Lightbox action applied to it. I duplicate it and add a border to the duplicate. Then I put a rollover action on it. (So that the image with the border shows up on mouse hover.)
Now the Rollover works fine, but the lightbox doesn’t. Instead of opening my Vimeo video in the lighbox, it basically jumps to a new webpage.
Can anyone tell me a solution? I want the rollover to work, but when clicked, I want the lighbox to open up.
Try doing things in a slightly different order. First, make your two images for your rollover. Then group them. Click once to select the group, then apply Rollover to the group. Make your settings in that Action so you see the effect you like. Finally, apply the ScriptyLightbox to the group. That should work. If it doesn’t, please post a link to an example page where it isn’t working. There’s another way to fix this, but it’s a bit long-hand and I hope you don’t need it.
On Dec 8, 2011, at 9:32 PM, Frank Ruggiero wrote:
Hi Freeway People.
My sincere thanks. That was the solution needed. Thank you.
To trouble you further, would you know how come the lightbox opens to the size of my browser (and not the size of the actual vimeo video - which is 400x225)?
I am trying to get it to open up at that size, and not blow it up to my browser size, but having a heck of a time finding a solution.
I’m not sure. It’s supposed to use the dimensions if you provide them in the Action interface, but in looking through the code, I’m not sure why it isn’t with remote URLs. I have seen the problem you refer to, and I haven’t solved it either.
