scripty lightbox HELP!!!!
afternoon!
I am doing a page to show off a dog that gets bred.
and my scripty lightbox is all screwed up -
http://www.grassrootsweb.net/arthur
Thank you all for your prompt help!
this is also doing it on another page - so the solution is doubly needed
Julie
You need the latest version of ScriptyLightbox. I just fixed this bug over the weekend.
perfect!! thank you
I was away and am just catching up w email - so if you posted I have not gotten there yet :slight_smile:
J
Hi Julie
If it’s the 4 images on the ‘Photo’ page, they all worked as they should do.
Regards
Lee
THank you - I did change the lightbox v. like Walt mentioned
J
On Jun 9, 2010, at 4:03 PM, Gray Owl wrote:
Hi Julie
Regards
Lee
real quick - why is my photo page jumping like it is??
J
J
Hi Julie
Regards
Lee
Sorry, where? Jumping how?
J
J
Hi Julie
should do.
Regards
Lee
the photo page seems to jump sometimes (almost like expanding and going back to size)- i saw it on safari but not firefox…
J
J
J
Hi Julie
Regards
Lee
Do a force-reload in your browser. Hold down the shift key and press
the reload button on your navigation bar. (Or, just clear the cache
from the Safari menu.) You probably have a bit of the old JavaScript
lodged in your cache from before you updated the site.
J
J
J
Hi Julie
they should do.
Regards
Lee
And remember that if you use the Title tag in your Link then you can add a description to your LB image.
Like here http://www.deltadzine.net/test/scripty_test.html
And dont use all those characters in your image file names: Sawyers Dan-(web)25.jpg
Dont use spaces and parentheses - better to stick to underscores and hyphens
And those pics could with being lightened a bit
Hope you don’t mind me jumping in Julie, but David how do you do it then??
Regards
Lee
Beautiful dogs!
Once you have created the SL effect by applying the action and then attached the Graphic Link to File.
Select your thumbnail and Edit>Hyperlink
Choose External from the options. Protocol: Other and type a # Hash (option + 3)
Then in the Title box below type in the text you want to appear.
OK dialogues and test!
Thank you!
and thank you Lee for asking!!
I know the pix do they just gave them to me - I need to work on them tomorrow - at the same time I will change the file name.
J
Thank you - They are my neighbors
On Jun 9, 2010, at 6:24 PM, LauraB wrote:
Beautiful dogs!
Thank you for that David.
Lee
That worked perfectly
Thank you
http://www.arthurbigboy.com
J
Thank you
J
Hi Julie
Sorry to say your link is not working.
Lee
THanks Lee
http://www.charthurbigboy.com
Thank you
J
Hi Julie
Lee
