Walter, are there any conflicts known yet with FW7 (responsiv)?
I have just discovered your ScriptyAccordion Action and I am thrilled by the quick and easy setup. (I have worked with Moo Accordion action many years ago.) A client wanted to change massive text into an accordion layout and it was done within 1 minute. Great!
And it works as far as I see on iPhone Simulator, but would be good to know. Thanks a lot, Hanna
The SA encourages a “liquid” layout by its very design, so as long as any inline HTML boxes (or pass-through images) you place inside your main accordion element are defined with a percentage width, you should be all set. You can set different widths for the outer HTML box (the one you applied the Action to) at the various breakpoints, and your content will flow to fit.
