Supposing I have a rectangle, and an arbitrary path. I’d like to use
the path to ‘slice’ the rectangle into two shapes, each with one side
the same shape as the path. How do I do that? I’ve been fiddlingon
for ages, and I just can’t remember how.
Phil
Ac onwacnigeað nu, wigend mine,
habbað eowre linda, hicgeaþ on ellen,
winnað on orde, wesað onmode!
use the path to ‘slice’ the rectangle into two shapes, each with
one side the same shape as the path. How do I do that? I’ve been
fiddlingon for ages, and I just can’t remember how.
I’m no expert, but I think you have to do something like this:
Duplicate the two objects as two separate sets, maybe on different
layers
1st set make object A in foreground
select all
object > paths > subtract
2nd set make object B in foreground
select all
There’s probably a better more elegant way of doing this…
