I do understand. What you need to realize is that Freeway does not read or understand HTML. At all. It generates HTML, but it cannot understand a single angle-bracket of it.
Freeway writes a binary .freeway document each time you press save. It stores the entire site in that one file.
When you publish (or preview a page), Freeway will check to see if the file exists in the designated Site Folder, or exists but has a different modification date, and will generate that page again (in HTML) out of the binary Freeway document. But that is a one-way trip. Changes you or others make in the HTML are considered by Freeway to be damage to those output files. They are not new information that Freeway will understand or use at all.
I completely understand what you would like to be true. But what I have been at pains to explain to you is that this is not something Freeway can or will do, no matter how much you may want it to.
You have two choices, as others here have pointed out already.
Duplicate the changes within Freeway. If the changes are only to visible text, this will be annoying but not difficult. If the changes are to internal HTML structures, then it will still be possible using the Extended interface, but not as easy to do. You will need to open the updated page in a programmer’s text editor, locate the new content, and figure out how to use the Extended tools to insert it into the generated code flow.
Never use Freeway to change this site again, only use a text editor or HTML-aware editing tool like Dreamweaver to make any further changes.
On Jul 10, 2018, at 2:53 PM, Matt Morris email@hidden wrote:
I am thankful for the comments…perhaps I’m still not clear.
Regardless of how I view my pages…in Freeway, with Freeway previewing in Safari, etc…the changes are not visible.
However, if I use Finder, and click the Index page file name…the “preview” icon-thumbnail in Finder…shows the changes. If I double-click, it opens the page in Safari with no graphics, etc…but the text reflects the changes.
If I could only post screenshots it may make sense.
