I’ve been having success with using the Sequence Timer Action together with the Target Show/Hide Layer.
Unfortunately when I’m trying to use the ST60 and TS/HL60 nothing happens. No action at all.
I’ve been to Action Forge and believe I have the latest versions: Sequence Timer 60 [1.0] and Target Show/Hide Layer 60 [1.2]. Actually, no other versions are available.
Any ideas?
No, why indeed? That would be great if that is the case.But how do I configure that? Say I go from Aqua to Cadmium, does it automatically continue after the 20th to the first in Cadmium?
I take it then that you can’t use the normal Sequence Timer if you have more than 20 images?
But isn’t this where the 60 version should come in, and why doesn’t it work? A bug?
I had a quick look at ScriptyFader, which might work for my purpose, but first I’ll need to find out why the 60 version doesn’t work. It seems so much more easy to get going, especially when I have everything more or less set up already. And I can use the stop onmouseover which you so kindly showed me…
A png. item at the bottom to get the shade and your mouseover item at the top to halt transition. Works fine with normal sequence timer, but as you can see, no action with the 60 version.
