I have a page which I am using as a template file and it gets modified by another program with data from our database. If Freeway re-publishes the page it removes our updates. I could simply delete it but I imagine Freeway would then attempt to delete the file from the server.
Don’t hyperlink it to anything, like your navigation or other pages. You can then have it as a “hidden” page - I have a few pages like that one different websites that I run. That way you can have the page on your site if you need to but no one else can see it. You can then reinstate it when you need to.
kind regards
Elizabeth
On 11/04/2012, at 3:17 PM, Kim Kohen wrote:
Hi all,
Is there a way to tell a page not to publish?
You can move and store it as a master page, they are not published as pages. That is the only answer I recall as this is one of the very frequently asked questions. It is also as frequently requested as a wish-list item. : )
Frank H.
On Apr 10, 2012, at 10:47 PM, Kim Kohen wrote:
Hi all,
