Hi, I’m a Freeway Express newbie and trying to make a page with multiple frames. The page is black but I can’t find how to adjust the frame color to match (defaults to white), or to simply eliminate the borders from appearing (preferred).
Frank, it might be suggested to work with something other than frames. The technology is dated and somewhat unreliable. Are frames essential to your web design?
Hi Frank,
If you still want to use frames with no borders simply select the frameset page and set the border width in the Inspector palette to 0px. You will get a warning about this being non-standard HTML but compared to using frames this isn’t really worth worrying about.
