Hi,
I am trying to figure out the shoppng cart. Am going through “Shop in a box” . At page 10 I have gotten confused. it says to select the Actions palette from the site panel. ?? There is no E-Shop Settings there. I loaded Freeway 5 into my Application folder. Should I have done something more? I am in Freeway Pro 5 2.0.
Tobé
Tobé Saskor
Websites and Photography by Tobé
59 Deerwood Lane
Pinehurst, NC 28374
Tel: 910-215-8818
Email: email@hidden
Websites:
www.bytobe.com (photo)
www.WebsitesByTobe.com
www.WebsitesForHorses.com
Hi Tobe
The most important of these is the E-Shop Settings action
where you will enter information about your Mal’s e-commerce account.
This is an Action which is applied to a folder, so select your Site Folder in
the Site panel…
Is this the bit you are stuck at?
Once you have your site folder selected in the Site Pane (on the left of your screen in Freeway)
open the Actions palette, if it is not already open,
and click on the + button in the bottom-left corner of the palette. A dialog
will appear listing all of the Folder Actions you have available. Select the
E-Shop Settings Action and OK the dialog. The Actions palette will now
display the E-Shop Settings user interface.
