One of the easiest reasons for a reply being bounced is if you reply
from the wrong mail address. If you have multiple e-mail addresses in
Mail, it is possible to set Mail to reply from the last address that
received a message, or from a particular address.
There’s also always a picker at the top of the mail message as you are
composing it, allowing you to change your From address there.
FreewayTalk is a mailing list, and everything you see here filters
through a piece of mailing list software called Mailman. We have the
reject bar set pretty high, which is why you won’t see bots on this
list, and only very rarely see a troll-like message. Only accepting
messages from the subscribed members is one of the lowest bars of this
set of criteria.
You also cannot send screen-grabs or other attachments, or messages
larger than 40KB in size. (A term paper’s worth of text, or one tiny
photo.) Sending mail that doesn’t have a text “part” to it will also
get you bounced, as in certain (thankfully rare) HTML mail
applications that don’t follow the rules.
On Nov 3, 2010, at 4:06 PM, Nathan Garner wrote:
Have started this new thread Steve, as for some reason each time I
reply to the other on, the moderator rejects my post?
One of the easiest reasons for a reply being bounced is if you reply from the wrong mail address. If you have multiple e-mail addresses in Mail, it is possible to set Mail to reply from the last address that received a message, or from a particular address.
There’s also always a picker at the top of the mail message as you are composing it, allowing you to change your From address there.
FreewayTalk is a mailing list, and everything you see here filters through a piece of mailing list software called Mailman. We have the reject bar set pretty high, which is why you won’t see bots on this list, and only very rarely see a troll-like message. Only accepting messages from the subscribed members is one of the lowest bars of this set of criteria.
You also cannot send screen-grabs or other attachments, or messages larger than 40KB in size. (A term paper’s worth of text, or one tiny photo.) Sending mail that doesn’t have a text “part” to it will also get you bounced, as in certain (thankfully rare) HTML mail applications that don’t follow the rules.
Have started this new thread Steve, as for some reason each time I reply to the other on, the moderator rejects my post?
Wow. Well something came along for the ride. Your message was listed
in Mailman as being over 40K (not by a lot, mind you) but that’s
pretty hard to reach when you’re typing plain text.
On Nov 4, 2010, at 7:58 AM, Nathan Garner wrote:
No juest a simple reply. Don’t worry it only happened on that one
thread.
there.
