SlideShows work only randomly
Hi
I updated this site to FW Pro 6 & Exhibeo yesterday. While testing the slideshows worked well. But they don’t now. I cannot see what is wrong.
Some work and mostly not. I’ve tried Chrome, Safari, Firefox, IE8. FF20 seems to work, mostly. But performance is sporatic.
Should the pages be in HTML5 or can HTML4 be used?
Or is it simply that Exhibeo is not ready for prime time?
http://www.rth.fi/keittokattilanka.html
Exhibeo mailing list
You probably already found an answer, but I learned from the Softpress support team that Exhibio will work okay even if the page isn’t set to HTML 5. It might not “validate” entirely properly, but it should work – at least in XHTML transitional, which is what my query was about. And it seemed to.
(Ran into another issue, which may be a conflict with ScriptyLightBox 3 running on the same page. Seemed to make the slideshow stop. Trying to learn some resolution on that now.)
Good luck.
