Hi Walt… I wonder if anyone has found a fix for smooth scroll not working when an exhibeo 2 gallery is placed on site?
I have never used these together, but forced to guess, I would imagine that that particular gallery uses jQuery instead of Prototype (or no library). jQuery and Prototype are equal-and-opposite. You would always want to use one or the other, but never both. SmoothScroll uses Prototype. It can’t be made to work any other way. If you can find a jQuery-based smooth scroll effect, you could use that in place of this Action. You’ll have to do a little hand-coding in the Page / Extended dialog, but that should be limited to pasting in one or three lines of code.
Thx Walter…
hmm… what would be the lines of code to get this to work>?
it is odd because the other Exhibeo themes work perfectly fine with Smoothscroll…
thx for any advice!!
