Software won't open PLEASE HELP
After the trial version expired today I purchased the software and installed it properly on my iMac 24" with Snow Leopard. I’ve been trying to open it but it crashes before open and gives me a message that says: "Process: WebAnimator2 [1094]
Path: /Applications/Easy Web Animator2.app/Contents/MacOS/WebAnimator2
Identifier: WebAnimator2
Version: 2.0.4 (???)
Code Type: X86 (Native)
Parent Process: launchd [108]
Date/Time: 2010-12-17 16:23:50.812 -0500
OS Version: Mac OS X 10.6.5 (10H574)
Report Version: 6
Interval Since Last Report: 942 sec
Crashes Since Last Report: 6
Per-App Crashes Since Last Report: 6
Anonymous UUID: 670D58D9-E321-4953-8454-67FA3933C8A7
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7ffffe"
I appreciate any help
Marcus
Easywebanimator mailing list
the weirdest thing is that the message it gives me now is:
“COMMUNITY TOOLBAR:
We’re sorry but the Safari Borwser version you are using does not support the community toolbar” ???
What in the world is that? I don’t know why I get this message when I try to open Easyweb Animator?
Any ideas?
Marcus
Problem solved:
Today is my lucky day! Ifound the solution, at least for my case. I hope that would be also your case. As soon as I tried to open Easyweb Animator I was receiving a massage that says
“COMMUNITY TOOLBAR:
After a while I remember I installed a toolbar application on Safari a couple of days ago called “netrenderer”. It’s used to render any website as Internet Explorer, so you can have a look how the people who still uses that program see the page. As soon as I deleted it and open Easyweb Animator, it worked with no crashes at all.
Hope it helps someone too.
Happy holidays
Marcus
As reference, Netrender is a toolbar for Safari
