Is it possible to a add a sound at a softer level. I have a sound file I like but the volume is a bit too loud. Any suggestions?
Hi,
You could import the sound file into Garageband (or similar app) and decrease the volume overall or in a section. (It’s also possible to fade in from silence or fade out.) Then rename the resulting file and import into Freeway.
I’ve been able to do alot of sound file manipulation in Garageband. It’s not just for teenagers
Jim
