I wonder if anyone can help with this
I have constructed a holding page http://www.sunset-designs.com/
The bottom line of text is giving me problems.
- In Page view I have entered three spaces between the two telephone numbers and the email address to differentiate them like so
Telephone: +44 (0)1544 209 Mobile: +44 (0)7974 156 Email: infoatsunset-designsdotcom
However when in Preview view and viewed in any browsers the three spaces are condensed to one and all looks rather cramped. I have tried using tab space with the same result. The only thing that worked was entering white text but this seemed a poor solution esp from an accessibility view.
2. The tail of the g in designs gets clipped in Internet Explorer. Altering/decreasing the leading clips the whole line and more of the line disappears the tighter I try to lead it. All looks fine in Firefox and Safari .
Pete
Use Option-Space, which is a ‘hard’ space. HTML ignores more than one
‘ordinary’ space.
best wishes
Paul Bradforth
http://www.paulbradforth.com
Web browsers all collapse multiple runs of spaces into a single
space. That’s been core HTML rendering behaviour since the very
beginning. Try option-space (makes a non-breaking space, which is not
actually a regular space character… and so isn’t collapsed. Try
space, options-space, space ,etc…
Gotta run! Meeting to get to.
k
Thanks very much Paul and Keith
Learning something new every day… I’ll try the different key combos
Still wrestling with the tail on the g though
Pete
I have found other areas where Internet Explorer appears to clip the
descenders of text on the last line in a box. I have discovered that
the workaround in these cases is to add an extra line with a (very
useful) hard space. IE then seems to behave itself. I’m previewing in
Net Renderer so am trusting its faithful reproduction of IE layouts.
Thanks again
Pete
Pete
