More and more I have a strange behavior on FW 5, HTML 5, no specific webpage: When I insert an element, it doesn’t appear on the net. No matter what kind of an element it is. “Add a code”, jpg, Textboxes… It is strange and I have no idea about the reason. But wait… there is more: when I command-x the missing element in FW and paste it onto an other page (same file), it shows up on the net (on this other page, after uploading of course). Any ideas? Any help?
Ha! Dave – thanks for whatchin’. It is on me. Or my computer. Since a few weeks I discovered also that firefox doesn’t show all videos on the net. I’ll try to find out, what the reason could be…
Firefox does not support the most widely-used video compression format – H.264 MPEG 4 – because of patent encumberment fears. I did hear that they were planning to introduce support at some point soon, though, as the patent holding group that owns and licenses H.264 has clarified their position further w/r/t browsers. You can support Firefox using one of the many HTML5 Video Actions, though, which use a Flash fallback to play H.264 MP4 when the native platform can’t do that. I have written two Actions, there’s a third I did not write, all available in the ActionsForge if you search on Video.
Duplicate the page in Freeway, remove the Add Code Action from one copy. Publish both, and post the URLs here. Then we can look at a “diff” to see what that Action is doing to make the difference.
On Jul 2, 2013, at 4:18 AM, GTPeter wrote:
David, it is the Add Code Action. If I take it out, everything appears suddently.
