I’m wondering if it could be a problem with the OS system as now and then the cursor on my iMac will go huge for an instant then revert back to it’s normal size. I have an iMac using OS X El Capitan Version 10.11.3
Ray
Intaglio mailing list
That’s a feature! Scroll down to “Call out your cursor” (the third item down). If you want to turn it off, go to System Preferences - Accessibility and uncheck “Shake mouse pointer to locate.”
Joe, ya got to be kidding… lol Thanks, I can now impress the DW… lol
BTW, is there a way I can get the up/down arrows back that were at the ends of the Scroll bar??? The programmer who removed those should be hung. Anyhow, thanks, bunches!!!
Sorry Frank, that was not my intention. I was just pointing out that the OS could be wrong. I had no idea it was a feature. Since Joe knows the features better than I do I just asked him an additional question.
I believe the folks reading this thread will come to the same conclusion that there was no intent and they will answer your question if they know the answer. Again, I’m truly sorry if I have caused you grief.
I don’t know. Under General System Prefs you can make the scroll bars appear all the time, but I don’t see the arrows.
There´s an intermediate update wearing the same revision number (2.9.4) but fixing the text-tool issue.
Thank you Nick! That was driving me nuts. The fix is much appreciated.
Frank
