Aha. Somehow you saved an HTM file in your Actions folder, and a properly-formed HTML file isn’t an Action, so Freeway is borking on that. Try the following steps to locate it:
Mac OS Lion or later: in the Finder, hold down the Option key, and choose Go / Library from the main menu.
Mac OS < Lion: in the Finder, choose Go / Library from the main menu.
Continue (in any version of Mac OS):
In the window that appears, navigate down to Application Support / Freeway [Pro or 5] / Actions
and start looking for any files that don’t have the .fwaction or fwactionb file-type extension. You should be able to spot this DIARY… file pretty easily. Drill down to any level you find within that folder. (If you have Freeway 5.6 or lower, the outer file will be named Freeway 5, if you have 6 or later, it will be named Freeway Pro. You may have both, and you should look around in this general location until you find it.)
On Feb 14, 2014, at 9:35 AM, John Bates wrote:
That’s part of the problem. It doesn’t say and the only connection the file in question has with anything else is a hyperlink from one of the pages.
The message says
'Action: “DIARY2013-14.HTM”, File: "Hard Drive:Users:Batteneye:Library:Application Support Freeway 5:Actions:General:DIARY2013-14.htm
This is a verbatim copy of the message, complete with all punctuation.
Thanks for your interest.
