Thank you for such a prompt response!
I did see that action and have downloaded it, although it said something about needing Javascript if memory serves me correct (I’ve been trying so many things I may be confusing it with something else). Also I couldn’t work out how to use it effectively.
If I use the BAM action, will people without Javascript still be able to use my site?
I haven’t used this at all, but I think it just uses CSS to do its thing. There’s no specific reason why JavaScript would be needed. JS is pretty ubiquitous these days (much better market penetration than Flash, for example) so you should be fine.
