How Come Paul Durnings Text Flow action doesn’t work in Freeway Pro 5?
It keeps on saying that there are no image map paths on the page.
Of course I’ve tried putting in a path, but it doesn’t work.
Does anyone know what I’m doing wrong?
Brian
Paul4
(Paul)
February 5, 2010, 9:40am
2
HI,
make sure that the image maps are not a child of any other box. Use the site pane to check the grouping.
I did all that and now there is a javascript error: thePath has no
properties
Brian
On Feb 5, 2010, at 4:40 AM, Paul wrote:
HI,
I also moved the map out so that it was no longer the child of the graphic box, but it made no difference. It just does not work. However, the message that there were no image map paths on the page did go away.
O.K. I Have got it working. I deleted everything and rebuilt the whole page, then published. It should work.
While it works, it sure makes a lot of DIvs to do what it does:
div id=“item3” style=“position:absolute; left:184px; top:115px; width:285px; height:226px; z-index:5; overflow:visible”>
