Hey folks, looking for some great examples of actual work people have produced with Vertical Moon’s Text-osterone and SWF n slide. I wish Vertical Moon had a Gallery section like Softpress.
Anyway, I’ve been searching around just to get a feel for what’s possible with these packages working together. Haven’t seen much.
Any thoughts? Seen anyone who’s done some cool stuff? Is it worth the 100 clams to buy?
I don’t know that it is anything to be proud of as an example but here
is something I did years ago using Text-osterone for the menu. http://www.clairejames.com/
Ok, thanks. Maybe I should rephrase the question. I’m looking about adding some animation to a new client’s site, and I currently suck at Flash. Simple pans, zooms and animated text should do the trick.
Might there be a better way of doing this, or should I just bite the bullet and learn Flash?
By the way, does anyone know how I could get ahold of a user manual for textosterone and SWF n slide? The software seems powerful, but I’m not having much luck flying blind.
I create all my Flash using Vertical Moon software. Don’t have Flash, never did. I use SWF n’ Slide Pro, Text-Osterone (works with Slide Pro too), Video2SWF, Image2SWF, and Audio2SWF. Work great, good docs, and excellent support.
I don’t do real exotic stuff, just bits and pieces here and there. This software makes it easy, a bit of a no-brainer and easy to learn. I like that.
Oh yes, the processing is pretty quick. There may be not much spectacular about their software, but it just works.
Have you tried the demos?
Jacob
this is a gallery I produced for a wedding photographer using SWF’n’slide using the flip page effect works well
