Is there an Action in Freeway 5 Pro or example that I could possibly look at, that will allow me to display to the user a selection of thumbnails, which will be actual screens-shots of an application and when the user clicks on a thumbnail, that thumbnail is expanded/zoomed in. When it is clicked on again, it then zooms back to it’s thumbnail size.
Any assistance/examples would be much appreciated.
Sounds light a good candidate for using Lightbox or a derivative of it. Weaver’s MooTools Suite has a version, he also has a stand alone version of Slimbox that can be used with Scriptaculous.
What version of FW are you using T - it is 5 Pro isnt it.
This action is part of the Standard actions included with Pro
To use:
Draw a graphic box on the page where you want your image to appear.
Size it and import your image.
Apply the Target Show/Hide Image action to it. Set the action inspector settings to Initially: Hidden you can leave the rest at their default settings. of Target Group: Indigo and Target #: 1
Select the text or graphic that you wish to trigger the image and apply a Rollover to it. In the inspector set these settings to Mouseover:Items, Target Group: Indigo and Mouseover#: 1
Restore settings you can play with until you get the effect you want.
