Top menu bar problem
I have freeway 5.4 and I can not open it at all now. If I go to my freeway
file it opens and I can edit and everything like I’m using freeway. When I’m
using it the top menu bar just says finder and if I try to use it its like
I’m in finder not freeway.
Did you try reinstalling Freeway? What changed on your system that caused it to go awry?
I’ve had issues with Freeway staying ‘focused’ but usually it snaps out of it.
