Would anyone happen to know if there a way to make html with an opacity (i.e. 70%)?
opacity (i.e. 70%)?
You can use rgba:
.style_name {
color: rgba(100,0,0,.7);
This will give the text a maroon color with a 70% opacity.
You could also use ‘opacity’ and target an entire element instead.
#id_name {
opacity: 0.66; /* CSS3 & WebKit */
-moz-opacity: 0.66; /* Gecko */
-ms-filter: alpha(opacity=66); /* IE8 */
filter: alpha(opacity=66); /* IE6&7 */
-khtml-opacity: 0.66; /* Safari v1.x */
You have options.
Twitter: http://twitter.com/XiiroMedia
Skype: toddbrilliant
Sounds good. Could you tell me where it goes (how to do it)…
Open the Styles window and create a style for the text if you haven’t
already done so.
Click the Extended button and in the Name field enter:
background
and in the Value field enter:
rgb(200, 54, 54)
(obviously you need to change these settings to the color you want)
Click OK to close the Extended window.
Now we’ll add the opacity setting for browsers that support it.
Click the Extended button again and in the Name field enter:
color
rgba(200,54,54,.7)
Here’s how the final result should appear in your CSS:
background: rgb(200, 54, 54) /* The Fallback */
rgba(200,54,54,.7)
Really old browsers will still choke on this but I wouldn’t worry
about that.
Thank you!
rgba(200,54,54,.7)
A minor typo. Above should be:
color: rgba(200,54,54,.7)
