Underlines disappear with ScriptyLightbox
I have styled 2 bits of text in an html item styled with underline-they are links to subpages. I have applied the ScriptyLightbox action to the html item so that the subpages appear in a lightbox. Works great-EXCEPT-when you close the lightbox, the underlines are not there. If I try to use the Text Link Style action, the lightbox doesn’t work-the links becomes links that open the subpage but not as a lightbox.
Any help with this anyone?
Thanks Jan
Post a link to your page.
Just in general, make sure that you use External Stylesheets whenever using the ScriptyLightbox, especially if you are loading your content from another page. Also, if you are loading HTML content into the lightbox from within your own site (not from a separate site) then you must use the PHP Make Insert Page Action on that content – you cannot load an entire page into the lightbox, only a fragment (without the HTML, HEAD and BODY tags).
Links with Lightbox are at the bottom of this page:
http://www.myreadycenter.com/alphasite/rcforworkwhat.html After you close the lightbox, the underlines disappear.
Links with Text Link Style action applied, the Lightbox doesn’t work:
http://www.myreadycenter.com/alphasite/rcathomewhat.html
Thanks Jan
